An early Christmas
SVcummins
Or a late one I guess
Will your new ring compressor fit my Deere big block piston? Do you have a special tool to dig the valve out of the piston?--Thanks--waiting for your answer---Tee
Its rare I use those ring pliers play careful with them... I think the only thing they are worked for me on is hydraulic lift cylinder piston rings.
That’s the only good I get out of the steel sleeve type i use
them for putting hydraulic cylinders together when the seals
stretch , I guess we’ll see which one I hate worse
Heck thats nothing, I pull a set of pistons out of a K 19 liter gas that melted the liner to. The pistons were for nat gas and was ran on propane or vice versa. Used a bottle jack to push out the liner with rod and piston in it.
