Angle drive
Axell
Location
Scandinavia
Hi!
Is an angle drive for the tachometer repairable?
Turning the brass cogwheel doesnt turn the output shaft to the cable. I can feel resistance and it also feels as if there is a similar cogwheel inside. It takes a bit of for to turn. Shouldnt it turn very easy?
I dont see any way to open it.
Tachometer and cable are fine.
This post was edited by Axell on 02/07/2023 at 08:12 am.
Sure, if humans made it ,we can fix it .
Ive never seen one , just a guess whats wrong with the worm drive is striped.
Take it apart marking every thing , photo everything as it comes apart ,might two weeks till it goes back together way things work out.
Hi again
The new angledrive arrived. Small compared to the old one. It fits although the bolts have to be much shorter.
Anyway it turns the wrong way. Does that have something to do with the tachometer is anti clockwise or is it the wrong angle drive. Can't find an anti clockwise drive.
By the way, how do you disassemble the dash? Will the steering wheel have to come off?
Yes the steering wheel has to come off. I can't help you with the tach drive issue, my Super Major is a '64 so has the Minimec injection pump and the tach runs off of the rear of pump. It runs counter clockwise too, only familiar with this set up. If you bought that from Agriline did you ask them about it?
(quoted from post at 15:34:53 03/11/23) Yes the steering wheel has to come off. I can't help you with the tach drive issue, my Super Major is a '64 so has the Minimec injection pump and the tach runs off of the rear of pump. It runs counter clockwise too, only familiar with this set up. If you bought that from Agriline did you ask them about it?
Hope it will come off easy. But think the former owner did renew the wiring so he must have been in there.
