Anitfreeze mixture
around here in Ohio a 50/50 mix is safe, I think it's best to mix the antifreeze and water together before you put it in a Therm-o-siphon system such as yours, the claim is that if you put one or the other in first the density of the antifreeze will not mix or therm-o-siphon
I do 50/50. I buy a gal jug of it then use and old jug and pour half in the old jug then add water to both so I then have a 50/50 mix. Now if you way up north it is better the do a 70/30 for max safety 70% antifreeze and 30% water give you max protection as per the chart on the jugs back label
