i have a 70 1020 with the stupid solenoid removed and the manual one installed. new glass bowl fuel pump installed. new rebuild on carb. problem is it will only idle. soon as you try to give it throttle the governor kicks in and she stutters and dies. i have the idle screw at 1.5 rounds out. and the load is 1.75 rounds out. choke is off. if i move the load needle when running it will not really do much even when trying to give it throttle. when she dies i have to reset it back to 1.75 rounds otherwise she won’t even hit. nothing has been adjusted or moved other than fuel pump and carb.
