Should my 300 (6 volt) have a bypass circuit from the starter to the coil? It never has had one as the wiring is original but sure acted like that. The past 6 months it has developed a hard starting problem for some reason. Yesterday I choked it, which I never have had to do in the past, and it would not pop, snort or anything until I accidentally let up on the key instead of shutting it off and it started and ran right away. I have had for over 10 years a Pertronix and it has always started within two or three revolutions. Would a weak battery do this even though it cranks over real good? My battery is quit old also? I did not have time or a long enough jumper wire to run from the battery to the coil to test to see if it would run when cranking this way. Coil had fire, 1/4 inch and a yellow color and when I checked a plug wire, all I had at the time was a 1/4 inch bolt I stuck in the plug wire and it never jumped a gap but it would kinda shock me. So I am now trying to figure out is it the coil or a voltage drop somewhere in the wiring to the coil, or a weak battery if that is possible. The tractor is 2 hours away so it is not just walking out the back door to do some testing.
