Another 460 farmall question.
So I was brush hogging with my new to me farmall 460 gas, it runs around 38-40 psi oil pressure at pto speed without any load on it, this was my first time mowing with it as I bought it a couple weeks ago and had to wait to start till I got a 3 point on it. It was around 40 psi when I started. Well I was just humming along mowing but I noticed the oil pressure dropping to around 30 sometimes a little lower around 25 psi. Before anyone says it yes, I'm buying a manual. But my question is, is this normal? Everything looks and sounds fine, does not appear to be leaking any oil, it does blow a little smoke out the breather tube. I checked the oil of course before I fired it up, it was right around the full line.
Any help is appreciated
Thanks,
-Garrett
It is normal for oil pressure to drop in a worn motor as the oil heats up. 25 lbs pressure is not good but it is adequate depending on what you are doing with it. If the mower that you are pulling is a 10 foot mower conditioner you are headed for trouble. If it is a six foot shredder you have many happy humming along years ahead of you.
It's a 5 foot brush hog, ok it only
dropped to 25 a couple of times, and then
came back up to around 30. Thank you.
I don't think you have anything to worry about. Just check the oil before each use. Make sure you keep it topped off. If you were using this tractor 8 hours every day I might think differently. If every thing else works good on tractor, oil is cheap.
How is the temperature running?
The warmer the oil gets the thinner it gets, especially running single grade. If not already, try running 15w40 diesel oil. It will be more stable as it heats up, the diesel oil is better suited to the older engines than modern automotive oil.
Be sure to keep a close watch on the radiator fins clogging with grass.
I dont actually know the temperature, the gauge is broke. I do have a new one I can put in and probably will tomorrow. I have and will continue to keep a close eye on radiator fluid and fins. (Warning really dumb question!!)Its ok to run diesel motor oil a gas engine??
Also I was doing a little more mowing and noticed the transmission gets pretty hot after 30-45 mins of work, around the same time engine oil pressure goes down. What's causing the transmission to get so hot? I just changed the fluid the other day.
Thanks
I would check the gage. It may be bad. Change with a known good gage and see if it does the same thing. Your oil pressure is fine otherwise.
Yes, it will be fine to run a 15W40 diesel oil in a gas engine. The additives in the diesel oils are better suited to the old tractor engines than the new oils recommended for automobiles.
My 8N starts out at 38 and goes down to +-25 when hot and mowing. It has been doing this for 20 years. The compression on this tractor was 90psi per cylinder and has been using 1 qt of oil every 5 hrs since I got it. Some day it will get the rebuild it deserves. I wouldn't be worried about it unless it is making noises with the drop in pressure.
Change the oil and filter. I second or third going to the 15w40 oil. That's what I run in all of mine, including a 460lp. If you go to the manufacturer website and read the fine print you'll find that these oils are intended for mixed fleet use.
As for the pressure, old factory gauges can be off and some of the new "made for" tractor gauges are also off. Personally, I have completely given up on aftermarket tractor gauges. I use Auto Meter or Stewart Warner gauges as they've held up for me over the years. There may be some good restoration type gauges out there but neither I nor my kinfolk have found them yet. The ones made in India seem to be the worst.
It's normal for oil pressure on this old stuff to drop somewhat once things warm up. 25 does seem a little on the low side. I wouldn't worry with 30. As long as it's not knocking or making glitter in the oil then it's most likely ok for what you're doing. If you were depending on it to do heavy tillage work then you might consider a rebuild before something gets damaged. For shredding and blading and chore work I think it will be fine with good oil.
The heat from the main case is normal. Were you able to get the transmission filter changed?
