Another Case O Matic Problem
Cyric30
Hello All
Yet another COM question i have a 66 model w/a COM
The tractor i have seems to work fine when its just started and Cool. but once it warms up and has run a bit the COM doesn't want to move the Old Girl, the Direct drive works fine. i just recently got this tractor so i dont know much about its history, good news is i have another COM for parts on another tractor. so possible diagnoses?
i know a fluid and filter change is in order for sure. B/W where is the filter for the COM on this year model? still in the front behind the grill? also what type of filter is it?
if you need more info please ask me im afraid its going to be bad though...
Cyric
(quoted from post at 23:14:58 07/08/15) Hello All
Cyric
I had a 400B that had the same problem. It turned out to be a plugged C.O.M oil cooler.
You will most likely have to go through the diagnostic steps outlined in the repair manual. That's how I discovered the restriction in the oil cooler in the bottom of the radiator on my 400B.
