another distributor question
djbnsp
gathering imformation for future referance
would a distributor and drive housing from a
WD work on a C thanks for the info so far
No! However if it is the mag replacement type distributor that uses the existing mag drive the distributor is the same for either application.
the WD never had a distributor, nor did the model C.. both would be aftermarket units that replaced a magnito... so the answer is probalby yes. look to see that the mag has a two tang drive like the magnito, then all is good.
<a href="http://s436.photobucket.com/albums/qq86/steve-ill/?action=view&amp;current=distributor.jpg" target="_blank">
distributor.jpg" border="0" alt="distributor
</a>
