Another funny
4520BW
Not quite. There is no stronger force that that holding a tall stack of plastic blueberry-picking buckets together, after your kid smashes them all together. You can yell all you like ..... too late.
If You dont mind a small hole in the bottom of the bucket that will cancel the vacuum -- If they are still stuck take the air hose to it -- Blow that bucket right off -- works good!
I blast the air from the top between the pails. a hole in a pail makes it useless as that is the first one you will grab when you drain the oil in a machine, just to have a big mess on the floor.
