Ken Christopherson
Hello all. Well, got the rear end 99% disassembled. Very surprised to find it was nearly sludge-free and that almost every bearing is like new (with the exception of the pilot bearing for the top shaft to input shaft). Expensive little bugger that bearing is! Anyhow, I think I know why the bearings are like new. They were probably all replaced within a fairly recent history. Looks like the H suffered an inner axle bearing failure on the right side. Case has been welded inside and out, and there is significant scrapes in the bottom of the case from the bull gear. Common issue, I know.
I don't have a whole lot of confidence on the weld not leaking (since the bottom of the tub was covered with dirt and oil), so I am sourcing another rear case from a salvage yard (told them to ensure there are no cracks). Also needed a pinion shaft for the right side as mine had a few chipped teeth. Bull gear looks good, so they must have replaced all bearings, bull gear, and welded the case up reusing the chipped pinion gear.
As if I couldn't add any more insult to injury... I taught myself something about pulling the pinion carriers. You MUST pull the bull gears before ou pull the pinion carriers otherwise you WILL break the inner bearing flange on the carrier. Ya, ask me how I know....
Anyways, a good rear case, pinion carrier, and pinion shaft will be picked up this week. The newest video is also up for viewing. Hope you all enjoy and are having a great start to your week. I'm learning as I go on this one, and this is by FAR the furthest I have ever disassembled a tractor. Done a number of motor teardowns, and some very light transmission work.. But never anything this in depth. This is FUN!
Farmall H Transmission Teardown and Inspection
