Alabama JD
I have a 1953 60 model. It has an 'add on' adapters hydraulics setup...T-ed into the side of the power-trol with remote hoses about a foot long. I bought the tractor and I don't know much about the 'add on' setup. My dad's old tractor had the old remote setup back in 1965. From what I have researched, it is pioneer quick connect. Anyway, the rock-shaft does not work. I have read that if it has a remote 'add on' which diverts the fluid somehow, the rock shaft will not work. Surely, they will not rotate when the level is operator. I tried putting a load on the shaft with a tool and nothing, but a much delayed shaft-rotation with nearly zero torque. I don't have any attachment with a remote for the pioneer so I cannot check it. What to do to make the rock-shaft work. Do I remove the 'add on' hoses from the power-trol and put plugs in the side or is there some other trick to make the system work?
