steve-in-ga
I have to remove the output pulley off the same gearbox so I can remove the gearbox to fix a seal leak. This pulley looks different than the taper lock setup on the input shaft. This one is also very rusty. There are 3 sketchy looking bolts, but no extra threaded holes to push the hub from the pulley )(first picture). These bolts also look like they go through the pulley and possibly into the housing (second picture). The key also looks like it's welded to the hub.
How should I approach removing this pulley?
thanks again in advance for your help
Steve
Steve
