On my Super A there are studs screwed into the bottom of the Radiator for mounting.
Is the same true for the SWD9?
Also when the radiator broke loose the fan went into the radiator core. The fan got bent up badly and so now I am straightening it.
Did not loose any metal off the fan. However i am working hard to get everything parallel. Then to get each blade at the right angle.
It will not be perfect.
So vibration becomes an issue. The diesel runs at a low RPM compared to a gas engine.
When the tractor gets started up what would you look for or listen for to make sure I will not damage the bearings or other things over time?
