(quoted from post at 15:13:19 12/01/23) Not since it's in reverse and I'm standing in front of tire
(quoted from post at 20:22:14 12/01/23) Since I have no one to help me a WD is
handy to push non running tractors in the
shed using reverse and the hand clutch
since you can easily do it standing on the
ground and then going back to steer the
other one.
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto167800.jpg>
What if you accidently get it into a forward gear? The tractor would be moving toward you engaging the hand clutch further since you are standing on the ground. It's just not a good idea.
(quoted from post at 11:00:32 12/02/23) I figured out how to mount a solenoid and push button start so I very seldom get off the tractor without shutting the engine off and it starts very easy when remounting!
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto167864.jpg>
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto167865.jpg>
happen to have a Auto-lite starter on my tractor which are hard to find replacement parts for but it has an external lug next to the switch. I had a Gleaner starter solenoid I used like Ford used and a Push button and it works fine. Pull switch works good also after cleaning up and adjusting contacts out?Cleddy(quoted from post at 20:00:35 12/03/23)(quoted from post at 11:00:32 12/02/23) I figured out how to mount a solenoid and push button start so I very seldom get off the tractor without shutting the engine off and it starts very easy when remounting!
How do you do it?
Thanks, that I knew. I thought you had a way to change the OEM starters. I've got a way, but it's not the greatest.(quoted from post at 22:07:42 12/03/23)happen to have a Auto-lite starter on my tractor which are hard to find replacement parts for but it has an external lug next to the switch. I had a Gleaner starter solenoid I used like Ford used and a Push button and it works fine. Pull switch works good also after cleaning up and adjusting contacts out?Cleddy(quoted from post at 20:00:35 12/03/23)(quoted from post at 11:00:32 12/02/23) I figured out how to mount a solenoid and push button start so I very seldom get off the tractor without shutting the engine off and it starts very easy when remounting!
How do you do it?
It is absolutely impossible to "accidentally" shift that transmission and odds are it wouldn't shift from reverse to any forward gear without the foot clutch being depressed. Not the best idea, but I've seen dumber ones.AaronSEIA
I've only ever been around 1 WD that'd shift gears without grinding using the hand clutch in my entire life. I wouldn't be worried about making a mistake that the tractor probably can't make.
AaronSEIA
