CasebyCaseMN
- Location
- MN Arrowhead
Hello all,
Finally had some time to return to the Case 800 diesel that I am in the process of overhauling. Today I pulled a sticky intake valve and found this under the valve. The valve was just sticky from old oil that had solidified on the valve stem, guide and valve looked pretty good. I was already planning on taking it to a shop, but I now have some questions as to the head. The valves are recessed very far into the head, and I am aware that they should be flush with the deck. From the pictures, is the valve seat ground into the head or has this one had inserts installed? Also, the crack in the seat/head is worrying to me, is this fixable? I know that coolant was in the oil before the rebuild, but the coolant gallery on the left side of the block was definitely cracked so I know coolant was getting in there.
Yes, the heads are in need of a good clean.
Thanks,
Al
Also, Jon F MN, you said that there might be a guy near Pine City who rebuilds these? Do you have his contact info? Thank you very much.
Thanks,
Al
