Broke the bead on one side of my tire only, the side with the valve stem, to replace the valve stem. The tire is a 225/75/R16. Got the bad valve stem removed and the new one installed easily enough. Still have the tire sitting on the tire changer, a HF manual changer, valve side up and am trying to set the bead. I have the core out of the valve stem and am trying to fight the tire bead over the part of the valve stem that is inside the tire, just the bottom portion. Not sure if I'm getting it over enough or not. Also trying to get the tire pushed up against the bead on the rim to inflate it. Not having any luck. Have the compressor set at a high pressure, and 80 gallon unit. Can't seem to get a seal so that the air will inflate the tire. Do I need to brake both beads to be able to get the tire to seal on the beads and inflate. All help and suggestions appreciated, still recovering from surgery last year and thought this would be an easy job as I've changed tires before, but this one is giving me a real problem. I'm using an inflating tool the you need to squeeze the lever to inflate, do I need to put the valve stem back in an change to a clamp on air chuck that once you clamp it on the air just comes out? Only reason I took the valvevstem out was because that'ss the way I've seen it done and my lock on uniit won't work without a valve core in the valve.
THanks
Bill
THanks
Bill
