Bought a New Idea round baler that had been sitting in a shed for 20+ years, an awesome buy that had seen very little use (not enough to wear the paint off the pickup strippers. Tractor end of the PTO shaft was lying across the top of the machine but therein ls the problem. The half that goes into the gearbox, the "inner" shaft, with the tractor half sliding over it. I struggled to get the shafts to slide together more than 6" or so and then had a duece of a time pulling it apart. Figured it was gunked up with old grease so tied a rag to a stick, soaked it in gasoline and shoved it in between the shaft and outer shield to clean the gunk off (a lot). Although I removed a lot of grease it only got marginally better, still can't get the shafts together more than 8'-10". I can only assume that it is old hardened residual grease but the inner portion of the shaft has a coating that is 1/16" or so that is even resistant to my pocket knife, almost like a hard plastic coating. Wondering if anyone has run into this issue and what kind of solvent might be most effective.
