Anti freeze tester
super99
I checked the antifreeze in the 550 yesterday with my cheap little floating balls tester that I have had for 30+ years. It only floated 3 balls, about 20?. I had to put a different radiator on it a couple of years ago and I mix 50/50 for everything, so I am sure that it should have been OK. It sat in the shed all last winter with no problems. I used it some last summer, but don't remember any reason to add only water to the radiator. I drained it overnite and will mix and refill with 50/50 today. I didn't think to check the other tractors to see if they were OK, I'll do that today. Can those floating balls testers go bad and not give a correct reading? I'm puzzled by this. Chris
I suspect..... that the older type are not necessary compatible with the newer anti-freeze.... in as much as they do work, but no longer correct. I have about 5 testers and some of them do not like the "long life antifreeze" and will read as you said.
Then accidentally get a battery acid tester thrown in the works and you will be mumbling to yourself.
Your freezer should run about 0 degrees. Take a sample and place it in the freezer over night. If your floating balls tell the truth (+ 20 degrees) the sample should be frozen in the morning.
I never considered that the newer anti-freeze types could give different readings with the ball tester. It would be interesting to check it.
Coolant based on Ethylene Glycol keeps getting heavier as the % increases co pure antifreeze will indicate all balls up. Sourced info includes: Pure ethylene glycol freezes at about −12 ?C (10.4 ?F) but, when mixed with water, the mixture freezes at a lower temperature. For example, a mixture of 60% ethylene glycol and 40% water freezes at −45 ?C (−49 ?F)
My words Pure ethylene glycol will begin to slush and restrict cooling at 12 degrees F. It proceeds to solid as above. As soon as it begins to slush, And before the thermostat opens, the engine will overheat. Pure ethylene glycol (chemically pure, not necessarily what in is a jug from auto stores, gets smaller as it cools to a solid. So, though it slushes up, it probably wont expand to crack castings. Jim
Info
My opinion. Now don't everyone scream at once!! Firstly I used this floating pointer type of tester. I must have seven or eight of them all over the place. Pretty much goof proof and the best thing is to suck up your water and then turn it upside down, squeeze more air out, and then sample again so the whole tester is filled to the tippy top plus some.
Here is what I found with the little ball tester. People use it incorrectly. Squeeze and get as much water sample as possible and then turn it upside down. NOW read the floating balls. Confirmed this test with 50%50 pre mix and also against the other type of floating needle tester. Now this is my opinion and as stated it was tested against other testers. Give it a try and see what you get.
(quoted from post at 06:59:15 11/17/19) I checked the antifreeze in the 550 yesterday with my cheap little floating balls tester that I have had for 30+ years. It only floated 3 balls, about 20?. I had to put a different radiator on it a couple of years ago and I mix 50/50 for everything, so I am sure that it should have been OK. It sat in the shed all last winter with no problems. I used it some last summer, but don't remember any reason to add only water to the radiator. I drained it overnite and will mix and refill with 50/50 today. I didn't think to check the other tractors to see if they were OK, I'll do that today. Can those floating balls testers go bad and not give a correct reading? I'm puzzled by this. Chris
Did you get all the old water and coolant out of the system. I have found this to be a problem in the past. I drain them try to put the required amount of antifreeze and top of with water.
Pure ethylene glycol will also act as a insulator, rather than as a coolant. Too, using it with water at too high of a percentage can do the same.
I know for a fact Kubota actually states to never use over a 50/50 mix for this reason. In fact I've heard from my local dealer that improper mixes account for alot of overheating, and cracked heads on the smaller Kubota diesels that are so popular.
I do believe I got fooled by a couple of those old testers this year. So I think they do go bad.
You should get a refractometer type tester.
Fill and refill the little tester several times to "wet" the little balls, and make sure there's no little air bubbles sticking to them.
If there's any little air bubbles stuck to the balls, they will float higher and indicate a lower freezing point.
(quoted from post at 09:29:53 11/17/19)
".....Here is what I found with the little ball tester. People use it incorrectly. Squeeze and get as much water sample as possible and then turn it upside down. NOW read the floating balls...."
Perhaps my little brain is reading this wrong. Yes, indeed more balls will float if you turn the tester upside down but that does mean it is reading correctly. The tester has "lighter balls on top" those became buoyant and float first. As the density of the mixture is increase by adding anti-freeze the "heavier balls" will become buoyant. If you turn the tester up-side down the lighter balls tend to push up the heavier ones resulting in an incorrect reading. Note, a gallon of ethylene gylcol anti-freeze is approximately one pound heavier than a gallon of plain water. Please enlighten me if I am missing something - here.
My question would be if it was designed to be read upside down why didn't the folks that have made them for fifty years print the scale upside down??????
