(reply to post at 02:10:14 10/24/20)
(quoted from post at 08:19:00 10/24/20) What is the current price for new weights from a dealer?
(quoted from post at 11:25:49 10/24/20)(quoted from post at 08:19:00 10/24/20) What is the current price for new weights from a dealer?
New 40 kg suit case weights from NH are $235 each
(quoted from post at 12:30:22 10/24/20)(quoted from post at 11:25:49 10/24/20)(quoted from post at 08:19:00 10/24/20) What is the current price for new weights from a dealer?
$2.67 per lb
mmeasurable, except maybe in the imagination. :roll:(quoted from post at 23:39:26 10/23/20) Not as heavy as cast iron and concrete, nor as corrosion prone as calcium chloride. However, like all liquid ballast, you are always fighting gravety by internal friction pulling up on fluid as gravety pulls it downward in the back of the tire as you move forward. Remember, that fluid is always moving inside the tire. I am not a fan of liquid ballast, worked in the Nebraska's Sandhills. Liquid ballast tractors used more fuel per acre than cast iron ballasted tractors did, same make/model doing same work pulling same equipment. I was one of the "bean counters" that kept track of expenses for a custom farming operation.
don't know about "implying"....just don't believe it.(quoted from post at 17:40:03 10/24/20)
JMOR
Are you implying you don't believe the theory that liquids inside tubes/tires causes enough friction to measurably raise fuel consumption?
(quoted from post at 06:15:32 10/24/20) > A big con to ethanol is it is very tasty and very toxic to animals. There are better better and cheaper ballasts today. Beet juice for example.
I think you mean ethylene glycol, aka automotive antifreeze. Windshield washer fluid, which IS methanol, is also toxic but animals aren't likely to drink it and leaked washer fluid tends to evaporate quickly.
Rimguard, aka beet juice, is certainly not cheap.
