I recently did a brake job on my 1949 8N. Unfortunately I'm usually alone. I'm a really strong guy but found my unloaded tires and rims a real PITA to maneuver on and off. Getting them off was ok but putting them back on was a real chore. Took me nearly two hours to get the right side back on. It seems when you jack up the rear end it's not a straight up-down path but rather an arc since the front end is still on the ground. I was only a couple inches off the ground. I found the only way to do it alone was to get just the right amount of shim/ lumber under the wheel and then slide the wheel under the drum using the weight of the wheel to force the slide. Problem was it took forever to get it just right and each time I had to move the entire wheel back off and manipulate the jack under the rear hoping it would hit right on the next go round. There must be a better way. I know they sell tire dollies and such but was wondering if any of you have a particular procedure for putting the wheels back on by yourself with minimal aggravation. Alternatively if you have bought a tire dolly that accommodates an 8N tire width please share the specifics with me?
