I have a 1964 ford 2000 4-cylinder with a marvel schebler tsx765 carb. It s always had a slow leak, even with the fuel petcock off it will leak about a drop a day. I ve tried a full rebuild kit and I ve got my float height set right. The carb bowl gasket and intake side of the carb are dry so I don t think it s a float height or float valve issue. Both plugs on the bottom of carb are new and tight. It seems like fuel is seeping through porosity at the front of the carb about halfway up the bowl. I have a couple questions:
1) is there any product I can use to seal the carb bowl?
2) what is the best replacement option? Has anybody had luck with aftermarket like what Steiner sells?
