Anyone want to help?
Dave/MO
I live in the Silex area. Does anyone live near by close that would like to help me with my tractor. I have done everything I know and it is getting fuel and spark but will not start. It turns over but will not start. I am lost.
If I was closer I would help you but being here at the Lake of the Ozarks I think I am a bit far away to do so. That said I have to go work on a 9N in a little bit that has not run in years and see if I can make it run after putting the oil pan back on after fixing the oil pump pick up tube. My e-mail is always open so if you want you could e-mail me and I can then give you a phone number if that would help you any. I know I have done that with a good number of people and it has seemed to help them
Dave,
lets start over again, year? 6 v , 12 v ?
front dizzy ?
side dizzy?
Was it running before? why did it stop? ex. you changed the points...sat for a long time etc.
You say you got spark...good spark?
You got gas.....in cylinder? plugs fouled?
what did you do so far to fix this problem?
someone will answer your question once you give a bit more info.
I could come up to your place Tues after work. I work in Washington. Will take about 1 hr to get there. Will need specific instructions. You can email me.
