AR pto shaft
I have the pto shaft out of my 1935 ar. I have never used the pto but now i want to .. I noticed on equipment to hook up you push the pin and slide the coupler shaft on untill it locks in the notch on the tractor pto. My question is my ar tractor pto has no groove or notch cut around the shaft. Was older equipment coupled up different? I'm not sure what to do. I'm thinking i need an adapter anyway.. to spline up to the standard 540 pto size and spline. So should i just drill a hole through shaft to pin adapter? Thanks for the help Randall Miller in Ohio
