Are new distributors pre timed?
stryped
I bought a new front mount distributor for my 2n. I put it on the tractor as is and got to wondering if these things are pre timed or not. The tractor is still not running right now, but I am not sure if it is due to this or other reasons.
(quoted from post at 09:53:01 03/03/16) I bought a new front mount distributor for my 2n. I put it on the tractor as is and got to wondering if these things are pre timed or not. The tractor is still not running right now, but I am not sure if it is due to this or other reasons.
ouldn't count on it, myself.
the front mounts are made to install only one way due to an offset tang drive.
set it's timing adjustment and points per book and see if you can at least get her started, then go from there.
Don't know if yours was timed or not, but I would check it. ANYTIME points are moved, re-adjusted, replaced etc, timing needs to be reset. It's unlikely timing being off a bit on a front mount distributor would cause no run. Might make for hard starting though.
(quoted from post at 15:26:17 03/03/16) If that's the trouble try starting it an hour sooner :D :lol:
lol, ty for that. not having a great start to the day here, and your post brought a needed smile to my face :)
I bought one of those distributors recently and while I am satisfied with it so far, be sure to check the point gap. The points on mine were just barely opening, and in order to get them to open the full .015 I had to remove the washer under one of the hold-down screws.
