Are these decent front tires?
Tire Diameter16 in
Tire TerrainAll-Terrain
Construction TypeRadial
FeaturesFits Multiple Makes And models
Tire Size235/85R16
BrandCrossmax
Vehicle TypeCar
Tire Width235 mm
Tire Aspect Ratio85
Wheel Diameter16 in
Warranty Distance50000 miles
Tire SeasonAll-Season
Tire Speed RatingR
Tire TypeLight Truck & SUV Tires
Tire Load Index120
Uniform Tire Quality Grade (UTQG)560AB
Tire Treadwear Rating560
Tread Depth16/32
Assembled Product Weight46 lb
ModelAT-1 LTR1601ATCS
Manufacturer Part NumberLTR1601ATCS
ManufacturerCrossmax
There a good chance that wide of a tire will likely rub against the axle housing
6.00-16 is 6.3” wide, 235 is 9.25” wide, that’s nearly 3” difference
Do you have 1 1/2” clearance between you present tire and the axle housing, probably need more to allow for sidewall bulge
You’ll probably need wider wheels to move the tire out some in order to run that wide of a tire
Flipping the rims around is a good way to span off a spindle
