That centrifuge oil filter is a FANTASTIC advance and works great. Nothing to replace, no cost just clean it out and back to work!My neighbour had an 825 about 40 years ago. I put rings in it back then due to blowby for some reason when it was fairly new. He used it for a lot of years. It did the job as his yard tractor. Another neighbour still has an 825 here also. Guess I am one of the few that actually did engine work on them. Lol. The centrifuge oil filter stuck out in my mind. There was a dealer here back then. I used to see the giant 4 wheel drive units also.
Mack has used that filter for everThat centrifuge oil filter is a FANTASTIC advance and works great. Nothing to replace, no cost just clean it out and back to work!
Scania used the same thing. If you look at a Case 2870 tractor you will see one there (Scania engine).
I have run Mack trucks for many years. Started out with a B61, then another one, then an R600, followed by 3 Cruiseliners, and finally a CL700with an E9-500 in it. This is not to mention several Freightliners and Kenworths. All the Macks had Mack engines but I've never seen one with a centrifugal oil filter! The B61s only had a partial flow LuberFiner filter. All the rest had spin-on filters but no centrifugal filters! What models have you seen that have them?Mack has used that filter for ever
I looked this up and apparently Volvo, after integrating Mack, started putting centrifugal oil filters on their hybrid Mack/Volvo engines. However these seem to be small replaceable filter cartridges, definitely not the same kind of unit as the Belarus or Scania uses, although the operating principal appears to be the same.I had two macks one a r 600 and the one I have now a r688 both full blood macks they have 3 filters two spin ons and one a centrifugal between the others
All input welcome. Any particular weaknesses? How is parts availability?
Thank you,
Glenn
if you have time to waitAll input welcome. Any particular weaknesses? How is parts availability?
Thank you,
Glenn
Thank you,
Glenn
