Auction today....WTHeck?
Straw Boss
Aumann's Pre-1930 auction today. The Case Disker brought $17,850!
I figured it'd go between $500 and $1,000. What am I missing?
the pictures are a bit grainy, but my best guess is that it read a 87A disc plow, my books say it was introduced around 1931, by 1936 the disc scrapers were standard equipment, I cannot tell they have been removed or if they never were installed it also is missing optional wheel pie weights which help with the draft on a hard pull, it would look real good behind a $2000 case L tractor
Same person bought the following items:
The 1897 price/repair catalog for
$1,155 raised an eyebrow also. I
have one just like it I think I
gave just a bit over a $100 for
it.
Glenn, are you sure this guy
bought all those items or just bid
on them? I poked the button
yesterday on an item or two and
one of them showed up on your
list.
Those are the items I found that the person bought, he bid on more items and I may have not found them all, as soon as that manual went over $500 I made sure he paid for it
Plow weighs 3750 lbs and with 7 discs in the ground it only turns over 65 inches whereas a 7 bottom 14 inch moldboard type plow would be close to 98 inches
It shows it as a 31. Oddly, that is a time after steam, and even the big crossmotors. The L was the biggest tractor of Case at the time. But a 65" cut may be comparable to a 4-16 plow at 64". If this was built by Case plow works, it could have been intended for any tractor on the market I suppose.
