Auger Cutting Edge
I've got a 6" auger with a cutting edge with an over an under bolt pattern. I can't find on the net any bolt pattern like this as they all seem to be side by side or a single bolt hole with a lip. My gear box says AGMO PH-2 with a 2" output shaft. Does anyone know if these edges are still made and who makes them? Or what is recommended for an alternative? Thanks, Rick
Make you own out of a old spring leaf. You can cut the holes with a torch. Been doing that for years and the spring metal is as good or better than the original cutting tips.
