Autolite Generator
Vmax2005
Working on a Case La 6 volt neg. ground generator GBM 4809. 2 wires coming out of generator, neither identified, both the same. When applying 6 volts to each wire, the rear wire (closest to brushes) makes the generator run clockwise (facing the pulley). When applying 6 volts to the front wire (closest to pulley) the generator runs slower and counterclockwise. Is one wire the field and the other the Gen.? Can a 6 volt cut out or any 6 volt regulator be used on this generator?
Z/
If the generator turns when voltage is applied to either wire it must be an A type generator. The field is the one that turns it slower, and opposite. The Make sure test is to motor the generator in the fast direction as you did, but then ground the other wire. If it slows but does not stop, the grounded wire is the field, and the other is the Armature. If it were a B type the field would not motor the generator with voltage applied.
The voltage regulator on the one you have must be well grounded. The field wire is grounded to make it charge. Jim
The Autolite generator on my VAC has a Delco Remy cut out on it. Hi/Lo switch in the dash works, however unlike the DR generators I'm used to, I can't get a Hi/Lo setting to suite me.
My SC has an autolite 4809 six volt neg ground generator. If you clean all the paint and rust off you should see a letter A and F stamped in the housing. generally the armature or A wire will be a heavier gauge wire then the Field or F.
For a regulator use one for a WD or WD45 Allis. The Allis regulator will be for a positive ground but will work with negative. Or switch your LA over to positive ground. I searched half the summer for a neg ground reg for my SC. Never found a one.
