axel bracket
okbill
someone have a picture of the bracket that goes under rear axel that holds fender brackets? lost mine took tractor apart in 04 just now getting it back together thanks bill.
fender bolts to top of axle.. the under bracket is usually a stabilizer holder.
ps.. best to say what model you are talking about..
soundguy
sorry soundguy 1950 8n,are thry called stabalizers that are under the rear axel?would you have a pic i seem to find them in partson this site. bill
Here's a pair.
thank you ok8n i guss i will have to find a pair as i have lost mine,my son overhauled his car in my garage recently can only imagin where they went,
Here's a set on eBay:
http://cgi.ebay.com/Stabilizer-Brackets-8N-9N-2N-Ford-Tractor-/120716379616?pt=LH_DefaultDomain_0&hash=item1c1b41c5e0
Check your email.
A word of caution---a bracket is a bracket is a bracket is not true--some are different. See the pic that OK8N posted then look att he ones on ebay..see how the gusset is located more to the center of the ones OK8N posted...I ran into this when I was trying to get my lift arms to not bind..Bought a set from a board member and my arms still bound up when lifting the arms..anyway between the two you will find that it does make a difference..Some may disagree but I have BTDT--they are NOT all the same..
Yes the hundred series' brackets are different than the ones for 9-2-8-N's . If you buy the aftermarket , rember the pins should be in "line"with the piviot points of the lift arms.
