Axle gasket does not fit
Axle gasket does not fit I ordered from yesterdays tractor part number 2N4035 from yesterdays tractor to go onto my tractor serial number 4035 from yesterdays tractor to go onto my tractor serial number 9N243859 which according to my shop manual shows a 1947 2N-2NAN Is what my tractor is supposed to be yet the gasket is a little to small and the holes do not line either anybody have any idea what is going on
1947,
Have you contacted Yesterdays Tractors to ask them about the situation? Over on the left side of this page there is a "Feedback Form" under the heading of
"Miscellaneous". You might try sending them a note.
Good luck.
Tom in TN
Paper gasket??? If so you will probably have to soak it in warm water and it will swell up some. I have hade to do it with an old dried out on.
Bingo.
Shrinkage.
Soak in warm water for awhile and try again.
Why? No one knows. Just do it.
Dean
You can also just spray a light mist on it while you are working it on are dab some water on with a sponge it don't take much...
