its called preload on the brg.
(quoted from post at 11:12:17 06/24/18) You don't want end play on a tapered roller bearing on wheel bearings. If you run them that loose the seals will not last long. I tighten my trailer bearings till they are tight don't turn then back them off till they turn freely. That sets the bearing on the spindle.
(quoted from post at 13:35:13 06/24/18)(quoted from post at 11:12:17 06/24/18) You don't want end play on a tapered roller bearing on wheel bearings. If you run them that loose the seals will not last long. I tighten my trailer bearings till they are tight don't turn then back them off till they turn freely. That sets the bearing on the spindle.
You're doing it wrong. Timkin, and all other tapered bearings should not have pre-load, or very, very slight pre-load under cool setting. Nearly all tapered bearings advise a back-off of ~1/4 turn once the bearing bind is felt.
Please don't advise this, it can lead to bearing damage, and possibly catastrophic failure.
