I am working on new to me Farmall H. I am new to them. It has been parked in the garage a while the left axle has a drip near the wheel. (Over time an ounce or 2??) I have read that when sitting outside a long time the differential can get water in it and cause the oil level to rise. I put a bucket under the check plug and it was about a gallon too full. (Going to drain and change later, Just checking how full or over full it was to start with.)
Seal bad or just because over filled? I also noticed a broken grease fitting on the top of the housing. Does it have oil and grease at that bearing?
Is any heavy weight oil good for these tractors? I read some oils are not good for bronze gears that I don't know if this tractor has??
Any tips or ideas appreciated. Thanks
