Axle pivot pin
bob6940
Does anybody know if there's an axle pivot pin available for an earlier 2n? All the ones I can find are after serial number 16xxx,I have a 14xxx number.
There are two pins available on this site. Pretty sure one of them is what you need but I cannot tell you which one.
This site also has one for 9ns,without a front mounted bolt but a top mounted cone-shaped bolt.
(quoted from post at 17:49:45 08/07/20) Does anybody know if there's an axle pivot pin available for an earlier 2n? All the ones I can find are after serial number 16xxx,I have a 14xxx number.
If you are looking for the "standard" pin and not the really long one used with the hand crank war models it looks like it is available on this site - from YT's description appears to be part number 2N-3126E but you should contact them and verify the length to be sure.
I believe you want the transitional pin used with the 9N style cast axle support as shown in Den's picture. It has the 8N style teardrop retaining flange on the front end but the cylindrical section is 4.25" long to work with the older 9N axle support. The 8N pin is only 4" long "under head" and is too short to work in the 9N style axle supports.
If YT does not have what you need send me an email - I can make you one that will fit correctly.
TOH
