B governor disassembly
WY JERRY
41 B, I want to replace the thrust bearing on the magneto side of governor. How do I get the magneto drive flange off? Thanks
you will need the mag drive flange spiecal washer ,spring and the brg assy and you probley need the gov case by the look of the flange i have these parts if i can help email is open
You will need to press it off. You may need heat. I broke the bevel gear trying to press one of these apart. I can take a picture of mine and post it tommorow.
