B n head gasket ?
showdown
My b n is 1947 it doesn't have a water pump was told it takes a different head gasket than the one with water pump.
no wayer pump//use the original b or a gasket,thats what you want..don't use the super a or super c as you will most likely over heat.
A,B,C,SA head gaskets are the same with no water pumps. The Super A1 and Super C--up have water pumps.
water pump gasket has smaller holes whitch constricks the water flow.itll heat up.i did it before by mistake.try it and see what happens.
