B or C Block
Ally Cat
Is there any difference between the early model blocks compared to the later ones. Was there any bolt holes added later. Are they totally the same. Thanks For Any Help.
The very early Bs used a different engine then the later ones. I do know the later B/C engines are the same but think the very early B engine will be a lot different
The later B's with starter and lights had two bolt holes on the carb. side to mount the gererator. The earley hand crank start had none.
Assuming you're not talking about the very early, rare Waukesha B, another difference is the early B engine number is stamped into a vertical face on the center, rear of the block- a little hard to see when it's in the tractor.
Not counting the 1937 Waukesha B engines, beginning in 1938 and running til the end of 1942, the B had a BE engine which I believe was 116 ci 3.25 bore x 3.5 stroke.
The C which was introduced in 1940 had the larger 125 ci CE engine 3.375 bore x 3.5 stroke.
Beginning in 1943 at tractor B64501 and running thru the end of B production in 1957, the B also used the CE engine.
The CA which replaced the C in 1950 also used the CE engine.
There were changes in the CE engine - primarily increasing compression ratio (CR) as gas became better and more consistent.
Engine s/n will mostly be steel stamped into edge of flange on drivers left of engine where it attaches to transmission - frequently under layers of paint. Format will be BE or CE followed by up to 6 numbers and a 1 or 2 letter suffix. Early suffixes were K (lowest CR for distillate), G for gas (4.9:1 CR on BE or 5.2:1 CR on CE?), then mid vintage about 1950 GA for gas (5.75:1 CR?), and last iteration PA for gas (6.25:1 CR?)
