B wedge wheel
Wingswd
Restoring a 1940 B and decided to stay with the wedge wheels instead of the loop. Anyone know how to set these up. It would seem that one wedge has a bigger hole and what I would call a oval wedge bolt. Does this go in the blocked space or opposite.
You want to put the two eccentrics wedges next to each other and the two solid wedges next to each other. You bolt the solid ones on tight and put them at the 4:30 and 7:30 positions and then bolt the two eccentrics on at 10:30 and 1:30. The eccentric bolt will be turned as you tighten the nut and make the fit nice and snug.
Zach
They have 2 lock type wedges and to that are on cams so you install them so the to set type sit side by side and the other 2 cam lock sit side by side. That way you can lock them both top and side and if done wrong guess what your wheel falls off. Yep BTDT and had more then one fall off and believe me that is not fun
A non locking wedge goes in between the the 2 blocks. This is to prevent the wheel from spinning. The 2nd non adjustable wedge goes next to the first. The 2 adjustable ones go side by side in the other 2 positions. I usually put the 2 non adjustable lugs on the wheel first, them I put them at 10:00 and 2:00, then slide the rim over top and jack the tractor so the rim hangs on them, them install the other 2. Bob
Thanks for all the info. put alot of time into this rim. welding in a patch, priming and wet sanding the snot out of it. It came out great. falling off would NOT have been good.
The cam bolt has a cross on the head. Point the long leg of the cross towards the rim. This will tighten the wedges against the rim and prevent the rim from coming loose. You may have to hold the cam bolt with a wrench to keep it from turning as you tighten it. Like old, don't ask me how I know.
