1000yds
What would be the valve "lift" of the cam in a 39 B? Just trying to determine if the cam is worn enough to replace. Keep getting a puff back through the carb once in awhile and it runs rough. New springs,valves,carb AND mag. Just about out of things to try. HELP!
Well I THINK so. I agree it would seem not to be though. Everyone seems to have their own technique. What's the foolproof way? 4 valves and two cylinders, you wouldn't think it would be rocket science.
Have you checked the inside of the Mag cap for Moisture or Carbon-Tracking..?
Both can and WILL cause what you describe...to the point they will NOT run..
You do know that these early JD's do run somewhat erratic by Nature..
Ron..
