B2472R manifold studs
MessingK
I don't have access to a parts catalog and was wondering if someone could help me out. I'm in need of manifold studs for serial number 300661 Model B with a B2472R manifold. I know they're 7/16 diameter, but am unsure of the lengths. Thanks in advance.
All parts catalogs are available online at jdparts.com. The B catalog will be in PDF format which means that you can save it to your hard-drive for future reference.
Id suggest substituting bolts. They will be cheaper and will allow you to remove your manifold in the future without removing the cylinder head or fanshaft. Deere swapped to bolts with the 50/60/70 tractor for this very reason.
On the late model "B" you want to be careful with bolts as there are two steel tubes that the push rods run thru in the head. If you crush the tubes you will most likely jam the push rods also.
