B2620 stoped moving
4520BW
Dads b2620 just stoped moving while he was mowing. The hyd fluid is full and was recently changed along with both filters. Neither ptos will work either . I was told they are know to wear out a coupling in the tranny and the part is no longer available. Has anyone delt with this? I have a shop manual on the way. Thanks
Can't help with your problem, but, have you talked to your local dealer? Hard to fathom something built between 08 and 15 would have parts unavailable.
You are talking about the ball coupler(s) on the propeller shaft. Its not inside the transmission and relatively easy to access. The part is discontinued but you may be able to repair the old one or find a salvaged one. Take your problem to Orange Tractor Talks and you will get lots of help.
TOH
