dcpky
Have a B-414 gas when I bought it last year clutch stuck finally broke loose put bush hog on ran it for a while done great but when going down the back of my dam first gear low range done fine holding tractor back then felt like clutch sliped could I have a glaze built up on clutch if so any tricks to getting it hot in hopes geting better grip with out splitting tractor Thanks again
Check the clutch pedal free play adjustment. Should be about 3/4 inch. Adjust by loosening the 2 bolts clamping pedal to shaft, put wrench on squared end of shaft and turn shaft until adjustment is achieved.
JimB
