caitriona
hi could anyone tell me if super dexta is man enough for a back actor digger, and if so woud it need any specail brakets connections ect
to connect it to tractor,the type ihave in mind is an old mc connel , it suppoe to connect stright on to 3ph
but ihave heard talk of some sort of sub frame needed. any ideas woul be welcome
caitriona
I assume you are talking about a backhoe attachment. I would not go to the trouble to mount one on an Dextra. The rear mount hoes are heavy and you need something a little heavier unless it is a real small backhoe.
I have an old McConnell Power Arm and that tractor would handle it fine. Mine is purely 3 point hitch mounted and has a PTO hydraulic pump. That said, the limitation is that the old McConnell is not a great digging machine. Better than a shovel, yes, but it is no Caterpillar excavator.
The one Dad bought new was used mostly on a JD 2510. Often you had to steer with the brakes!
When we went to put it on an AC D17IV-180-185 a lift arm hit the oil tank. There was a kit available that moved the hitch point forward on the backhoe. Unfortunately that moved the hoe back and made steering worse! A loader on the tractor made it just right.
thanks to you all for taking time to reply, so i take it the dexta will handle it ok with a little bit of a struggle, this icould probley live with. what would the differance be between
the old mc connel and say one of the newer smaller type back hoe implements at digging on the same fordson dexta, dexta is roughfuly 39 hp
its a little super dexta 1962,
