Back Up And Running
Caryc
Due to not finding any kind of high temp epoxy anywhere in town, I just put the new manifold on today. The block didn't really look that bad and I figured with a new manifold and gasket, it was better than just a new gasket. I'm 67 years old now and I'm just going to hope I die before it starts leaking again. Let somebody else worry about it. :mrgreen:
I got lucky in that with the new manifold, the new muffler assembly that I put on didn't leak at all around the clamp. It looked pretty straight and I did have a hydraulic jack pushing the pipe up while I tightened the clamp. I had tried it on the old manifold and it leaked.
Kind of like a puzzle putting the carb and the air tube and the manifold clamp on. I finally did it in the right order and managed to get everything to fit. It also helped to have the carb still loose.
I kept having trouble with the manifold clamp hitting the oil gauge hook up fitting in the block until I got everything together loosely and everything fit right.
(quoted from post at 17:46:16 01/19/14) Glad you got it going Cary. It will outlast us all!
Thanks. I might add that it was a new manifold from Tisco that the new muffler fit straight with no problems or leaks.
(quoted from post at 18:37:08 01/19/14) You are one lucky man..
Well I'm only half lucky. Did you see my post about my bank account being wiped out? Hopefully that will be taken care of Monday morning.
