Back with a very dry topic
RedMF40
Not from Iceland!
So I've been absent due to some computer problems. Laptop went crazy, cursor had a mind of its own. Wandered aimlessly across the screen. Then the screen itself shifted from one menu to another. It was like a thing possessed. Someone's looking at it, don't know if it can be saved. In the meantime I have a refurbished PC I bought locally and I can get online again. So I wanted to insert myself back into the conversation, which I've been able to follow on my phone.
So for the dry topic: Oil dry. Gotta love it. ANyone have a favorite? I've made a bit of a mess with a recent engine swap, even though I tried to be careful. I'm using clay kitty litter, which seems to do a good job. Also sawdust that I scoop up from recent chainsawing. Those two things. I don't actually have the product that's meant for this purpose. Is it any better?
Also---seems that I've seen people pour their oil dry of choice on the actual stains, after the wet oil puddle is gone. Is there ANY value in that, other than looking at a patch of oil dry instead of the stain itself? I'm not too concerned with totally erasing the oil stains. It is a garage floor after all.
And there's even a third part to this question: How do you go about it? Rags first? Then soak it up with oil dry, or just walk away and hope it dries up by itself?
Thanks in advance
Gerrit in Maryland
I use a mop with degreaser mixed in unless it is a big spill then the cheap oil dry rural king sells. Quick story..axel bearing out of a tractor and I get in a hurry and pull the axel housing out with out draining the oil, 5 bags of oil dry and 3 buckets of dirt to keep it out of the floor drain.
(quoted from post at 05:09:45 05/21/20) I use a mop with degreaser mixed in unless it is a big spill then the cheap oil dry rural king sells. Quick story..axel bearing out of a tractor and I get in a hurry and pull the axel housing out with out draining the oil, 5 bags of oil dry and 3 buckets of dirt to keep it out of the floor drain.
That was one of the big spills for me--pulled the half-shafts from the parts car out of the rear end, oil dumped on the floor. Shoulda known better. Little Honda CR-V, was able to contain it with some rags, maybe a quart or so drained out.
I have found clay litter to be the same as commercial Material. The main thing is never get clumping anything (for that purpose).
I have found that doing the "Twist" on some new Oil dry, when the first batch has gotten 95% of the oil absorbed works wonders on the stain. It seems
to both cover some from turning it to dust, and actually absorbing more due to the better contact at that scale of particle size. Jim
I use sawdust from my table saw, feed the sawdust to the wood stove and if I want to clean the stain I put paint thinner on it, rub it around a bit with a brush, and soak
that up with sawdust or a rag, then into the stove.
Usually my first line of attack is go for the dirty rag box.
If I don't have dirty rags, then the oil absorb.
If the finish is good and I want to really get rid of the mess, then follow up with scrubbing the floor with Safety Clean or diesel.
One time many years ago I scored a bunch of damaged bags of kitty litter to use for oil absorb. It worked well on oil, but I found out if there were any water or anti freeze involved, it would melt the kitty litter, turning it into brown slime that was like walking on ice!
Not sure if it was just that brand, but I sure had to be careful using it around water!
I used to work with an older fellow who was meticulous about a clean floor, he would put down some floor dry and then rub it in with a brick,
until it was ground up. Left the floor looking pretty good!
Keep a bucket of dry dirt around for oil spills. Kitty litter not as
absorbent as products made for oil spills,IMO.
I agree with dry soil or just sweepings from the shop.
Let it sit on the spill for a little while and and then sweep it up.
In a few days, there is not even a stain left.
I use the oil dry towels any more, they work great. not much diff cost, no dust no sweep after. you have to get the right towel thou. pig.com where got them, now they are available all over I think,but this is who I dealt with when running shop. ask them send sample pak of there diff types
I had a part time job working on farm equipment/tractors, and we used kitty litter.
It's cheaper and works well. Just sprinkle it all over the oil spill, and let it set.
Sweep it around with a broom a few times and sweep it up. I even recycled/reused it
until it was saturated. Hardly leaves a stain. Was cheap and works very well. I even
got a bag for myself here at home. Mark.
We had pig mat and floor dry where I worked. Funny part was floor dry with oil could be put directly in the trash but pig mat had to go through the hazardous waste process. Go figure.
I live in the yellow clay hills of Iowa so endless supply of clay then after sweeping it over the spill a while I leave it overnite then sweep it around some more pick it up and put were it will get burnt with the tree pile. Then I put a small amount of old pre mix concrete mix down for a few days and it cleans up good.
Thanks for the suggestions, glad I asked. I like the "doing the twist" idea. Dry up the oil stain and get some exercise at the same time. Probably stick with the clay litter for now, looks like pulverizing whatever material I use into fine dust is the way to go.
Pre-mix concrete is an interesting idea as well.
Gerrit
Use oil dry but sweep it up. I have found sweeping it out the front door left a clay based sticky mess just in front which tracked back into the shed when I drove through it. Had some kids use the shed and they used a cement block to grind in the oil dry. That worked great.
I hate all brands of oil dry. I use straw and hay chaff. When it is cleaned up the floor is not all gritty. Before the straw stuff I used sawdust. Lightly oiled sawdust also works as a floor sweep as well. You can get double use from some of the saw dust.
One problem with kitty litter poured on an oil spill on the floor, the garage cat mistakes it for a newplace to do its thing. I have
epoxy painted floors so rags now soak up most oil spills but a big oneneeds kitty litter. gobble
Just get cheap oil dry and throw on it. When it has pretty well soaked the oil up, scoop up the wet stuff and spread the dry around with a broom and then shuffle your feet around to grind it into the floor and then sweep it up. The stain will be gone.
I am an Auto Shop teacher at a local high school. We use as much of the Wood Shop sawdust as possible. Kitty litter gets kicked around too easy, oil dry is glorified kitty litter. Kids leave tools and such on
the ground and if they have grease or oil on them, the stone sticks to them. That kinda scares me......I don't like the idea of something like a stone being picked up off the floor on accident and dropped into
some important location in an engine, trans, brake system, etc. The saw dust can be a mess but it sweeps up real nice, you can burn it easy, and it works FAST.
I put cardboard(freezer type boxes) down before jobs . That helps keep the floor pretty clean and catches a lot of the small dribbles. Gives time to get the bigger ones caught before they get to the concrete floor. I also use old seed sacks when draining oil for jobs they can be changed on top of the cardboard. The sacks also catch a lot of dirt thay can go right into the wood stove as I scrape crud off to find things.
Cheap cat litter x2. Years ago bought a bag of el cheapo deluxe cat litter. On the bottom of the bag said it was made by Floor Dry Corporation or
whatever the parent company is called. Had a bag of floor dry at the time. Couldn't tell any difference. Pretty much figured it was about same thing
bagged as cat litter. Was probably 1/3 the price of the smaller bag of Floor Dry.
