Backhoe attach
Gagne
New to tractor world. Own a MF 1635. Just bought hoe MF 1580. It has 3 hoses. Assume the 3rd hosr is a return. My tractor has 2 sets of remotes. How do I attach and if I need to install a return line where does it go? Can anyone help.
you should ask your dealer that sold it to you should only have two hoses one supply one return and you might not be able to just plug it in because them hoses have there own control valves and the hoe has its own
Not so ,I don't think . The third line is for the relief drain when you get to the end of stroke on a cylinder. Will need to plum back to the tractor case.
3 lines could be related to the backhoe valve having a power beyond function. As marloweg posted, get the right info from a dealer, hooked up wrong it could do damage that will cost you a lot. And while you are at it, get the books for the tractor and the hoe. The books may have the info on how to attach the hydraulics correctly. They will have maintenance info you will need to care for the unit.
Welcome. You will get more help if you go down to the test forum, make a few posts, so you can get your post count up so this forum will allow you to post pictures.
