backhoe on tractor
alanmeg
I have 7610 Ford that Im trying to hook a Ditch Witch backhoe onto.The backhoe has three hoses on it,and my tractor has dual remotes.where do the hoses go and what position do I need the levers in on the tractor?Any help would be greatly appreciated>
Not familiar with that brand backhoe. Most I see are 2 hoses, you detent or use a shock cord to hold the hyd lever open & the controls on the backhoe all work from the one flow of oil. You would need to set the backhoe for open center hydraulics which I believe your tractor has.
I don't understand the 3 hoses......
--->Paul
I would guess your remotes won't flow enough oil.
And the 3 hoses could be for pressure,return and power beyond. So you can tap directly into your hyd. system.
