James in Ok
I have a 89  580k 4x4 case backhoe the shuttle shift seems to not work properley when it does go in it works fine just geting it to go is the problem any answers? thanks James
heavyequipmentforums.com
These guys might be able to help you, but you have to get so many posts in before you can post a new thread..
James in OK - On that 580 I think on the passenger side of the engine you will find a dip stick (laying almost horizontal by the frame) that goes to the shuttle. If you are low on oil (even a few ounces) the shuttle/torque converter will not engage quickly (sometimes you even have to rev the engine a little). If I remember correctly - to check, get the tractor on level ground, put the transmission shift lever in 4th, the shuttle shifter in neutral, with the engine idling. Pull the dipstick, clean, re-insert, pull the stick out, read the guage and add what you need (hytran or equivalent). It may only take a few ounces and start engaging normally with the shuttle shift, forward and reverse. Let us know. bob f.
