Bad battery charger?
550Doug
Location
Southern Ontario
This spring I've tried to charge up 4 12v batteries but have had no success. Either all 4 are dead (but read 8 to 10 v on a voltmeter) or my battery charger has gone south. It is 25 years old and NOT an automatic unit. How can I tell if the charger is the problem? I do get power out of the leads to the posts.
Are the 4 batteries wired in parallel and you are trying to charge all four at once or did you try all 4 separately?
Check voltage at the battery posts with the charger connected and running.
voltage must be 13.5V or higher to charge a 12V battery. Sounds like your old charger has weak or failed rectifiers, not too hard or expensive to replace. If it has button diodes, many tines the cheap connectors are not connecting with the button terminals. A cleaning and tightning of the contacts will sometimes be all that is needed to repair the charger.
You need an ohmmeter to check the rectifiers for open or shorted condition.
Have you checked the individual cells with a hydrometer? With readings of 8-10 you have 1 or two bad cells in those batteries, and you probably won't charge them.
its been my experience that batteries as low as 10 have at leastone bad cell and are unchargeable. Most chargeable batteries read in the `11 area. At least thats my experience. Nuff said Henry
Hook the battery to a known good battery and read the voltage it should jump up to around 14 volts or so with the charger on.
I have found that older batterise that have been ran down and left setting discharged for a long time may never charge back up. Not sure why but it is mostly what I have seen.
HELLO 550 Doug.
To charge the batteries with a 12 volt charger you need to have all the positive posts together and all the nagative posts together. That would parallel them into a single 12V system and a 12 volt battery charger should charge them.
Time to do it will depend on charger rate of charge and batteries condition.
Guido.
Shorted diode will smoke the transformer.Crimp connections on clips are often bad.heating at the crimp means voltage drop.Cutting back to clean wire and soldering joints will fix lazy chargers.I like copper clips but most are too cheap to buy and use them.
