ScottG
Hey Guys
I'm Back! Thanks to Bruce, I narrowed my problem down and hope someone can help me narrow it down alittle furthur. I have a 49 front mont 12v conv. It has been running for a while, maybe 20-30 min, shuts off and won't start back for maybe 10-15 min. Today when it shut off I checked fuel flow:ran good, jumped switch:no goChecked plugs, looked like a yellow/bule spark, Today when it shut off and I finally got it restarted, it ran for maybe 5 min and shut off again. That tells me something is heating up and failing. Could it be the coil? Resistor? Condensor? Or any other ideas? Would like to replace most probable first to cut down on expenses.Thanks again for all help. it is very much appreciated!!
The color of the spark isn't important; it's the distance it jumps that counts. Are you checking spark w/ an old plug gapped to 3/16 or 1/4"?
If you jumped the ignition switch and that didn't work, jump the resistor. But, you could easily have an intermittent short just about anywhere in the ignition circuit. You find that by following the volts w/ a meter or light, jiggling wires/connections & seeing what happens. Start at the coil & work backwards. You need to do this as soon as it stops.
In the unlikely event that the condenser is bad, they usually take the points along w/ them. What happens is they fail & allow the spark to arc across the points. The points will be pitted & burned. Usually. It's been a long, long time since I've seen a bad condenser.
And lastly, because you have a front coil & it's a 12v conversion, the odds of a coil problem increase. Does it have any other resistor(s) in the circuit other than the OEM ballast resistor?
50 Tips
Hey Bruce,
Thanks for responding, I don't think there is another resistor in the system. I was checking with a light and was getting power all the way to the coil when the tractor wouldn't start, thats what made me think of the coil. If I check the coil with a meter when the tractor is able to run and then again when it wont start, will I see a difference if its bad?
Nope. Unless the coil is visibly fried, you don't own a meter that can tell you if you have a good coil (and neither do I!)
Don't be so quick to suspect the coil. I'll bet that half of the coils purchased for these N's replaced a working coil; in the process of replacing it, the problem was fixed (bad grounds/connections) or the new $30 coil didn't fix the problem.
Coil problems are difficult to diagnose. For starters, round coils are pretty robust & square coils aren’t, but neither one will hold up to a poorly done 12v conversion that allows too much current to the coil. There are a few ways to see if a coil is bad, but it’s not possible to determine if a coil is good w/o some expensive testing equipment. If you detect a dead short or high resistance in the coil w/ an ohm meter, it’s bad. If it’s cracked, it’s bad. If a sidemount coil w/ battery voltage to the primary will not jump a ¼” gap from the secondary wire to the block, it’s bad. But, here is the hard part: even if you do not detect a short, even if it will produce a spark, even if it’s not cracked, that doesn’t mean the coil will work when it’s hot & under a load. So, it’s a process of elimination. If the tractor starts & runs fine for 30 minutes or an hour then cuts off & refuses to re-start, and you checked for spark at the plugs & it had no spark at all, AND you jumped the resistor (if it has one) that’s a good sign that you have a bad coil. Let it cool off, restart it & if you have a good spark, odds are it’s a bad coil. But, even then, you might end up w/ a spare coil on the shelf!
For the moment, forget the coil.
Let it stop once more, then jump the resistor. If that doesn't do it, pull the distributor.
Remember, the most common electrical failure (no spark, weak spark) points on the frontmount are:
1 The insulator under the concave head screw.
2 The insulator at the end of the points where the copper strip attaches.
3 The copper strip grounded to the plate.
4 The condenser wire grounding.
5 The pigtail/tab not making contact.
6 Incorrect positioning of the spring clip on the plate causing the pigtail to ground.
7 Incorrect seating of the coil on the distributor.
Before you start checking, look at the points. Are they burned or pitted? If not, check the gap, .015 on all four lobes.
If the points are ok, chances are the condenser is as well. So, start checking w/ the meter.
First, make sure your meter/light works (don't ask....)
Now, follow these steps:
1. Coil off, cap off, points open. One probe on the brass screw & the other on both sides of the open points. On the side closest to the cam, you should have continuity. Not on the other side! If you do, you will also have continuity everywhere because the points are grounded.
2. Coil off, cap off, points open. One probe on the brass screw & the other anywhere on the body of the distributor. You should have no continuity! Now, rotate the tang on the distributor....as the points open & close, you have continuity (closed) and lose it when they open.
3. Coil on, cap off, points open. One probe on the lead on the top of the coil, the other on the cam side of the open points. You should have continuity!
4. Coil on, cap off, points open. One probe on the lead on the top of the coil, the other anywhere on the body of the distributor. You should have no continuity!
50 Tips
Thanks Bruce, Ill pull the distrib tomorrow and check that before spending $$ on a coil. Thanks for your time and help!!
